memory requirements for cisco asa 5510 to use asa version 8.2
Jul 23rd, 2009
Hi all. I intend to upgrade my asa 5510 to version 8.2(1) with asdm 6.2(1). From cisco url(http://www.cisco.com/en/US/docs/security/asa/asa82/release/notes/asarn82.html#wp310503) i found that the memory requirement for flash ram is 512MB. But my asa 5510 has only 256MB. Is this sufficient? Pls advise. Thks in advance.
robertson.michael Thu, 07/23/2009 - 07:36
  • Silver, 250 points or more
Hi Don,
The ASA 8.2(1) image is about 15.5 MB and ASDM 6.2(1) 11 MB, so you'll need at least 26.5 MB worth of free space (check 'show flash') in your flash before upgrading.
As for DRAM, 8.2 certainly uses more of it than previous versions, so if your memory utilization is already high (check 'show mem'), you might want to consider an upgrade kit.
Hope that helps.
-Mike
keithannette Mon, 09/07/2009 - 05:37
If you do a show memory on the device and if it has less than 20% free, Cisco recommends to upgrade the RAM
