Trouble logging into a wlan 1240 mbssid
Hi there
I have some trouble logging into the configured SSIDs on a 1240.
I can see all the SSID's, but I can't login. On Windows, it "just" times out, on Mac, I get the message: "...talk to your administrator". I can't see any obvious thing in the config (find attached).
I configured 2 SSID's, each with a different VLAN. I want the AP to broadcast / announce both of them. I'll do a 3rd, which I want to broadcast as wel, but this one will have radius authentication (against WIndows Domain).
Andre
Any Help is highly appreciated. Thanks a lot in advance.
Robert.N.Barrett_2 Thu, 07/23/2009 - 10:59
  • Bronze, 100 points or more
I don't see anything obvious in the config (assuming you are configuring your clients to use WPA with the proper PSK). Why not temporarily remove all encryption/security to just make sure you're not having any VLAN/DHCP issues?
