Flex Links
Jul 23rd, 2009
I want to implement a backup link between switches, one link will connect the switches directly and the backup link will connect the switches through a switch and two AP's. Because of design reasons, I can't enabling STP.
I'm looking for something similar to Flex Links, but, to use Flex Links, the 2960 switch must be running the LAN Base Image, and the switches that I want to configure are running the LAN Lite Image.
Do you know something similar to Flex Links that I can use with Catalyst 2960 Lan Lite image switches?
Thanks in advance.
Giuseppe Larosa Thu, 07/23/2009 - 20:54
Hello Cesar,
Unfortunately no.
I would consider if STP can be used but you have already checked this.
So I would suggest an upgrade to LAN base image.
Hope to help
Giuseppe
iyde Thu, 07/23/2009 - 23:31
Upgrading from LAN Lite to LAN Base is equal to hardware replacement :-(
Giuseppe Larosa Thu, 07/23/2009 - 23:48
Hello Ingolf,
I see but if STP cannot be used what option is left to manage a L2 redundant topology ?
it should keep shut the secondary link and manually try to enable it when primary fails and then when primary link is restored what happens ?
Hope to help
Giuseppe
