CUCIMOC over VPN?
Jul 23rd, 2009
Hi All,
We run IP Communicator over a VPN client as a matter of course but, as an OCS user, we're trialling CUCIMOC. Whilst it registers fine we can't seem to setup a call through the VPN.... i can't see anything in the release notes, so any ideas?
Cheers,
Stu
htluo Thu, 07/23/2009 - 04:41
Are you in softphone mode or deskphone mode? What's the symptom of the problem?
Thanks!
Michael
stu_syn Thu, 07/23/2009 - 04:50
Thanks for your help Michael,
Softphone mode..... the client thinks it registered but CUCM says "unregistered".
You can attempt to make a call but nothing happens.... no response at all.
Interestingly if you use it as Deskphone control mode with IP Communicator it works fine.... bizarre.
I know we could use phone proxy on the ASA but all of our clients use VPN.
Cheers,
Stu
htluo Thu, 07/23/2009 - 06:41
What version is CUCM and what version of COP file have you installed(if there's any)?
Softphone mode is a SIP phone. You may look at CallManager trace to see if there's any INVITE for the call attempted.
Michael
stu_syn Thu, 07/23/2009 - 07:38
It's CUCM 7.1(2) with the inbuilt CSF option
It seems fairly fundamental as CUCM doesn't think the SIP device is registered.
Cheers,
Stu
samuel.suen Mon, 07/27/2009 - 01:03
I got the same problem. Indeed, I got there is no option for me to configure the CM IP Address on CUCIMOC client. How the client know the CM IP address and do the registration ??
Samuel
stu_syn Mon, 07/27/2009 - 01:06
Samuel,
That's a slightly different problem. Mine registers fine over the LAN.
You set the parameters via registry setting using gpedit.msc, the installations instructions should tell you what you need, but if you get stuck - let me know.
Cheers,
Stu
