Catalyst ME-4924-10GE - Fast ethernet management port
Jul 23rd, 2009
I would like to mirror one of the Giga ethernet port to the only Fast ethernet management port that we have on Catalyst ME-4924-10GE. Is it possible?
Overall Rating: 5 (1 ratings)
Marvin Rhoads Thu, 07/23/2009 - 05:10
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
While it may be possible, it is strongly not recommended. Speed mismatch aside, the management port is not architected to provide the wire speed switching that the access or uplink ports are.
See the Installation Guide (http://www.cisco.com/en/US/partner/docs/switches/metro/me4924-10ge/hardware/installation/guide/HIGOVEW.html) which states:
"The management port is used (in ROMMON mode only) to recover a switch software image that has been corrupted or destroyed due to a network catastrophe. This port is not active while the switch is operating normally.
You should designate one of the normal ports on your switch as a management port, used for configuration and monitoring traffic. D o not connect the management port to this network, it is only intended to be used from a direct console connection. "
Hope this helps.
andy_goes Thu, 07/23/2009 - 05:35
Thank you so much for your reply, I already have find this guide.
One more question: Is it possible change the speed to 100 on the giga ethernet port? We are using a GLC-T (1000BASE-T) because we need have RJ-45 and in this transcever we can't do that.
Leo Laohoo Fri, 07/24/2009 - 01:41
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
If you do "sh interface ", what is the speed the interface is capable of negotiating?
