Ws-x6182 T1 Controller Card config question
Jul 23rd, 2009
I just put a 6182 controller card in my Cat6500 - when I set the 10/0/0 timeslots I don't get a
interface Serial10/0/0:0 - Like I would normaly see from a controller card. They only thing I see is
interface Port-channel10
no ip address
controller T1 10/0/0
channel-group 0 timeslots 1-14
description XXXX
controller T1 10/0/1
channel-group 0 timeslots 1-24
controller T1 10/0/2
controller T1 10/0/3
The Port channel - show ? I am not familar with this can someone explain?
Port-channel10 is up, line protocol is down (notconnect)
Hardware is EtherChannel, address is 000d.662c.ea8a (bia 000d.662c.ea8a)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Auto-duplex, Auto-speed
input flow-control is off, output flow-control is unsupported
Giuseppe Larosa Thu, 07/23/2009 - 21:29
Hello Gabrielle,
you mean you have a flexwan module installed? WS-6182
What type of port adapters is placed into the flexwan module you can check this with
sh diag
you can find here a list of supported T1 port adapters
int port-channel 10 is another object and it is related to etherchannels not to ports in slot 10:
you can check etherchannel defined in this system with
sh etherchannel summary
Hope to help
