Joe Clarke Thu, 07/23/2009 - 09:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
What version of IOS are you using? What arguments should the script take?
steve.orphanos Thu, 07/23/2009 - 09:21
The IOS version is 12.2(33). I would like to create a script that when executed would execute the following commands.
Interface Gig 1/1
Shut
Interface range Gig 2/1 - 6
Shut
Interface Gig 2/20
shut
Interface range Gig 2/23 - 24
Shut
Then have another script to turn those interfaces up.
Joe Clarke Thu, 07/23/2009 - 09:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This should do it for you:
Switch#tclsh flash:bounce-ports.tcl shut
Switch#tclsh flash:bounce-ports.tcl noshut
steve.orphanos Thu, 07/23/2009 - 10:31
Do i just copy the file bounce-ports.tcl to the cisco router? If so where does the file get placed?
Thanks again for all your help
Joe Clarke Thu, 07/23/2009 - 10:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You can copy it to the local flash of the switch, or leave it on a network server. For example, the script can be run directly from TFTP:
Switch#tclsh tftp://10.1.1.1/bounce-ports.tcl shut
