Table name in SQL for partition
Answered Question
Jul 23rd, 2009
If I wanted to do an SQL search in CUCM6.1.2 for calls made by a particular partition what would I use for table name?
The partition we have setup for some users is: pt-Hastings
So I was wondering how do I list my query:
run sql select callingpartynumber, originalcalledpartynumber, finalcalledpartynumber, duration, datetimestamporigination, datetimestampdisconnect, "partition(??)" from car:tbl_billing_data where "partiton" IN ('pt-Hastings')
Correct Answer by Steffen.Baier about 7 years 8 months ago
Sorry, was to quick..You want CDR ...
Info:
callingPartyNumber = 5 Digit Extension Number of the Calling Party
originalCalledPartyNumber = 5 Digit Extension or Longdial Number with 0 for Access Code or 97xxx
finalCalledPartyNumber = 5 Digit Extension or Longdial Number with 0 for Access Code or 97xxx
originalCalledPartyNumberPartition = example P-Trunk-Select
callingPartyNumberPartition = example P-IPphones
finalCalledPartyNumberPartition = example P-Trunk-Select
origDeviceName = SEPxxxxxxxxxxxx 12 Digit in Capitals
destDeviceName = example [email protected]
Example:
select * from CallDetailRecord where callingPartyNumber='58999'
gives you exactly all calls made by calling Party 58999
select * from CallDetailRecord where callingPartyNumber like '5899%'
gives you calls made by the digits before the % and
any length behind it.
0004969% would cover all calls to Frankfurt Area Code Germany
select * from CallDetailRecord where finalCalledPartyNumber like '0004969713671_8'
would give you the exact range from
0->9 before the last digit
Overall Rating: 5 (1 ratings)
Steffen.Baier Fri, 07/24/2009 - 03:50
Have a look if you find it here:
select NumPlan.DNOrPattern as DirectoryNumber, Device.Name as DeviceName, Device.Description as
UserDeviceProfileName, Device.LoginUserid as UserId, DeviceNumPlanMap.Display as
DisplayIntCallerID,DeviceNumPlanMap.Label as LineTextLabel,numplan.alertingname as
AlertingName,DeviceNumPlanMap.MaxNumCalls, DeviceNumPlanMap.BusyTrigger,
TypeModel.Name AS PhoneType, DeviceNumPlanMap.E164Mask as ExtPhoneMask, NumPlan.CFADestination as
CallFWDALL, NumPlan.CFNADestination as CallFWDNoAnswer, NumPlan.CFBDestination as CallFWDBusy,
devicepool.Name as DevPoolName
from numplan, devicenumplanmap, devicepool, device ,TypeModel
where DeviceNumPlanMap.fknumplan = numplan.pkid
and DeviceNumPlanMap.fkdevice = device.pkid
and device.fkdevicepool = devicepool.pkid
and TypeModel.Name = 'Cisco 7970'
and numplan.tkPatternUsage = 2
order by numplan.DnOrPattern
Correct Answer
Steffen.Baier Fri, 07/24/2009 - 03:53
Info:
Example:
j.mccartney Fri, 07/24/2009 - 06:16
Thanks for your help, I was able to get the query working from your posting. It works great!
Thanks again.
John
