Masking CCM PIM Type 10 Network VRU Label
Jul 23rd, 2009
UCCE - 7.5.5
CVP - 7.0
CCM - 6.1
We have a Type 10 Network VRU configured with a label 8222222222 on the CCM Pim.
Everything is working fine from a call routing functionality.
Is there a way to mask the label 8222222222XXX from appearing on the phone when the route point is dialed?
Courtland
There is a UCM service paramater that controls the display of the dialed number.  In UCM 7.x the paramater is " /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} Always Display Original Dialed Number".  The default is False.  Set it to True, and the CTI RP DN should be displayed instead of the UCM VRU label.
Courtland Holder Thu, 08/05/2010 - 08:19
Always Display Original Dialed Number solves this issue but can create another. When this option is enabled and an extension is call forwarded, the calling party would not see where it is forwarded to.
Here is what we did.
Set Connected Line ID Presentation option of Connected Party Transformations on the route pattern to 'Restricted".  When the number is dialed th display now shows 'To Unknown Number'
