from transparent to routed - ASA supporting EIGRP
Answered Question
Jul 23rd, 2009
I have a ASA upgrade, where a 5520 ASA configured for transparent is currently supporting EIGRP with only ACLs - permit eigrp ..... source destination (host 224.0.0.10) - the replacement 5550 ASA will be configured for routed mode and a "router eigrp AS" process will be applied. Once an ASA is configured in routed mode, with an EIGRP router process enabled, how is the firewall configured to support EIGRP?
thanks, Kevin
Correct Answer by Jon Marshall about 7 years 8 months ago
Kevin
"so, even though there are numerous ACLs assigned to, let's say, both the inside and outside ASA's interface, there no longer is the need for "permit eigrp source destination" ACLs?"
Correct, because in transparent mode the EIGRP traffic was passing through the firewall whereas in routed mode with the firewall running EIGRP this is no longer the case ie. the firewall is now an EIGRP neighbor.
Jon
Overall Rating: 5 (1 ratings)
ksvy_ksvy Thu, 07/23/2009 - 10:57
Jon, great link, thanks
thanks, Kevin
Correct Answer
Jon Marshall Thu, 07/23/2009 - 11:08
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Kevin
Jon
ksvy_ksvy Thu, 07/23/2009 - 11:34
Jon, simple enough, makes sense.
thanks a bunch,
kevin
