Administration problems CCX Enhanced 5.0
Jul 23rd, 2009
Hi Netpro
I have a cluster to Unified CCX Enhanced 5.0(1), but when i try to configure application, upload a script or create a folder the application this message is showed:
Create a folder
Error while handling the input request.
com.cisco.app.ApplicationException: can not acquire ClusterMutex
com.cisco.config.ConfigException: Store config record - error: config request timed out
Create a Application.
com.cisco.config.ConfigException: Create config record - error: config request timed out
Any idea?
Regards.
joluc_denmark Mon, 06/14/2010 - 08:16
Just experienced the same problem on a Premium v. 5.0.2:
"can not acquire ClusterMutex; nested exception is: com.cisco.config.ConfigException: Get config record - error: config request timed out "
Any explanations?
Known error?
johnny
Yorick Petey Mon, 02/07/2011 - 03:22
Got the same issue on UCCX 7.0, any feedback on your issue?
Thank you.
Yorick
frzhang Fri, 04/08/2011 - 15:29
  • Cisco Employee,
Locks in CET most likely. Open a TAC case.
