DN for SIgn-In
Jul 23rd, 2009
I had a DN/Translation pattern set up to route directly to Unity with a routing rule that directed callers to sign-in. This was so that they could check voicemail when not at their own phone, and not be prompted for a password if checking vm from another subscribers DN. Anyhow, this worked with CM 6.x., but after upgrading to CM 7.x things stopped working.
In short I had this configured:
DN 8004 translation pattern, change calling party to 8004, change called party to the Unity Hunt Pilot (4200).
Unity Directed and Forwarded Routing Rules on called party=8004 route to Sign-in.
Effectively dialing 8004 should change any "known" DN to 8004 (so that Unity wouldn't jump to a password prompt) and just play "enter your ID".
If there's a better way to do this someone please share.
Thanks in advance,
Brian
