Replacing a non-redundant Sup 720 on C6500
Jul 23rd, 2009
We have a single Sup 720 installed in a Cat 6513 which has failed (and is creating a number of problems). I've worked with TAC and have a brand new Sup 720 to replace it with. Both the MSFC and PFC versions are the same between the existing and new.
Here's my question - can I just insert this new Sup 720 into the redundant slot, let it sync the config, and then force a failover? Or am I going to have some kind of a problem since the existing one has already failed (show module shows it has failed)?
Jim
Roman Rodichev Thu, 07/23/2009 - 14:24
it won't sync the config if the primary sup has failed. Remove bad SUP, put new one in, copy paste config
Mark Yeates Thu, 07/23/2009 - 19:44
Jim,
I would say it would depend on how faulty and what the issue is with your current SUP. You could always give it a shot (since you probably have already planned downtime anyways). Just make sure you have a backup config.
A while back I was able to do what you are planning to do and it worked fine for me. Although the issues were rather minor it was still accomplished.
HTH,
Mark
