VOIP implementation
cisco steps
We are going to implement, new softswitch- (true VoIP) solution will use the Cisco PGW2200 for the ACD..it will run on SUN NETRA using solaris 10. the solution has many components, the AS5400XM gateways, the Cisco software which will run across WINDOWS & UNIX, & the workstation coding.
Cisco stuff
CUCM - Cisco Unified Communication Manager
IVR
ICM
CVP
PGW2200
any help to get some heads up and learn before the implementation will appreciated
ldardon
You can implement Cisco BTS 10200 Softswitch or class4 soft switch. The Cisco BTS 10200 Softswitch provides the major functions performed by traditional Class 4 tandem and Class 5 Central Office (CO) switching systems. It provides call-control intelligence for establishing, maintaining, routing, and terminating voice calls, and it also serves as an interface to enhanced service and application platforms.
http://www.cisco.com/en/US/docs/voice_ip_comm/bts/5.0/command/guide/tools.html
