cisco 1200 ap vlan
I'm trying to make sure the configuration of the ap's works with our network cisco 3550 switches.
This is the configuration for one of our APs.
version 12.3
no service pad
hostname Admin_6
clock timezone GMT -5
clock summer-time R recurring
ip subnet-zero
ip name-server 172.31.13.13
aaa new-model
aaa group server radius rad_eap
server 172.31.13.13 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 activity-timeout unknown default 600
dot11 activity-timeout client default 600
dot11 vlan-name Native vlan 300
dot11 vlan-name pennstate vlan 301
dot11 ssid pennstate
vlan 301
authentication open
guest-mode
dot11 arp-cache
dot11 phone
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid pennstate
countermeasure tkip hold-time 1
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
power local cck 1
power local ofdm 1
no power client local
power client 5
no preamble-short
channel least-congested 2412 2437 2462
station-role root access-point fallback shutdown
interface Dot11Radio0.300
encapsulation dot1Q 300
no ip route-cache
bridge-group 255
bridge-group 255 subscriber-loop-control
bridge-group 255 block-unknown-source
no bridge-group 255 source-learning
no bridge-group 255 unicast-flooding
bridge-group 255 spanning-disabled
interface Dot11Radio0.301
encapsulation dot1Q 301
no ip route-cache
bridge-group 254
bridge-group 254 subscriber-loop-control
bridge-group 254 block-unknown-source
no bridge-group 254 source-learning
no bridge-group 254 unicast-flooding
bridge-group 254 spanning-disabled
interface FastEthernet0.300
no ip route-cache
bridge-group 255
interface FastEthernet0.301
no ip route-cache
bridge-group 254
interface BVI1
ip address 172.31.13.65 255.255.255.0
no ip route-cache
ip default-gateway 172.31.13.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
snmp-server community b0wl1ng RW
snmp-server community BROWSE RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps entity
snmp-server enable traps disassociate
snmp-server enable traps deauthenticate
snmp-server enable traps authenticate-fail
snmp-server enable traps dot11-qos
snmp-server enable traps switch-over
snmp-server enable traps rogue-ap
snmp-server enable traps wlan-wep
snmp-server enable traps config
snmp-server enable traps syslog
snmp-server enable traps cpu threshold
snmp-server enable traps aaa_server
snmp-server host 172.31.13.14 b0wl1ng
radius-server attribute 32 include-in-access-req format %h
radius-server host 172.31.13.13 auth-port 1645 acct-port 1646 key 7 052D273D121F1D3B
radius-server vsa send accounting
control-plane
bridge 1 route ip
wlccp ap username WDSuser password
line con 0
line vty 0 4
end
dancampb Fri, 07/24/2009 - 05:35
  • Cisco Employee,
This is not a valid configuration. You need to have a bridge-group 1 defined and associated with the native VLAN. Currently you don't have either.
ok, my bigest concern is how to setup the cisco 3550 to make sure it will accept the vlans created on the APs.
APs has two VLANs
301 - wireless clients
300 - Access Point Management Ip address
on the Cisco 3550:
I used also 300 to manage the cisco switch.
So, how to do I configure the switch to allow the APs vlan to go thru the router?
Here is the configuration for the cisco 3550
en
Config t
hostname LV-126B-W-13-3
enable secret 5 $1$27ar$DnvrYBhnNW5eyTF2JgHIe.
enable password 7 0307585A5E5A744058
username admin password 7 1414115A54517F2732
ip domain-name lv.psu.edu
ip ssh version 2
int range f0/1 - 24
description Wireless
switchport access vlan 300-301
switchport mode access
no shut
interface GigabitEthernet0/1
description Trunk to Cisco6509 router
switchport trunk native vlan 300
switchport mode trunk
no shut
interface GigabitEthernet0/2
no shut
interface Vlan1
no ip address
no shut
interface Vlan300
description Academic
ip address 172.31.13.3 255.255.255.0
no ip route-cache
no shut
ip classless
ip http server
banner motd #
** WARNING: Unauthorized access to this system **
** is forbidden and will be prosecuted by law. **
** By accessing this system, you agree that your **
** actions may be monitored if unauthorized usage **
** is suspected. Only authorized Penn State **
** Lehigh Valley Campus **
line con 0
exec-timeout 0 0
line vty 0 4
password 7 1511085D5C7F7E283E
login local
transport input telnet ssh
line vty 5 15
password 7 094F4D584150421E1D
no login
end
wr
