Warning message
Istvan_Rabai Thu, 07/23/2009 - 18:11
  • Gold, 750 points or more
Hi Bruce,
The config may be similar to the following:
aaa new-model
aaa authentication login default group tacacs+ local
tacacs-server host 10.10.10.10
tacacs-server key YYYYYYYYY
username TESTUSER privilege x password ZZZZZZZZZ
This implements the failover scenario you requested.
If the communication with the tacacs-server fails then the local user database will be used for authentication.
The "aaa authentication login default group tacacs+ local" command has the effect on all lines by default, including the console line.
If you want to implement this on select lines only then you have to create a named authentication method:
aaa authentication login TEST group tacacs+ local
line vty 0 4
login authentication TEST
In this case the authentication method will have effect on the vty lines 0 to 4 only.
Cheers:
Istvan
Bruce Summers Fri, 07/24/2009 - 03:04
Thanks Istvan
appreciate the information...I was hoping to read a bit about the configuration...I'll test this config you provided in my test bed...
thanksagain.
