Public IPs - Usable via FE Ports?
Jul 23rd, 2009
Hello Everyone,
Our new T3 connection has been assigned a block of public IP addresses (/29). One IP gets used on the FE port as the gateway with 5 public IP addresses remaining.
Our router has 4 FE ports.
I was hoping I could attach our 4 devices directly to the FE ports. Each device would have one of the 5 public IP addresses.
The FE port with the gateway IP assinged to it works. But the other FE ports aren't working. I guess it was wishful thinking that the other 3 FE ports would automatically work.
How can I make this work without getting 4 separate IP blocks for each FE port and without using an external switch?
Thanks in advance.
Overall Rating: 5 (2 ratings)
Giuseppe Larosa Thu, 07/23/2009 - 21:37
  • Hall of Fame,
    Founding Member
Hello Frankie,
what device is this and if it is an ISR router do you have an etherswitch module installed ?
if there is an etherswitch the ports have to be configured like switch ports
IP address goes to interface SVI vlan X
let's say X=5
you need to do the following:
to create L2 vlan 5 (broadcast domain)
depending on the type of module this has to be done in different ways
for example:
router# vlan database
vlan 5
apply
exit
( to be written don't use ctrl-Z here!)
int vlan 5
! public ip address here
ip address x.x.x.x y.y.y.y
! note important
no shut
! repeat for all 4 ports
! also for the one you have configured
int f0/0
switchport
switchport mode access
switchport access vlan 5
if you haven't an etherswitch module you should connect the routed FE (the one you have configured) to an external lan switch and then the servers to other ports in the switch
Hope to help
Giuseppe
iPhrankie Fri, 07/24/2009 - 10:52
It is a Cisco Router 3825.
We are using the two on board gigabit FE ports and an HWIC-2FE card that gives us two more FE ports.
So, I guess these aren't really a switch. They are more like four independent ethernet ports?
Can you still do a VLAN with the four FE ports?
Giuseppe Larosa Fri, 07/24/2009 - 11:07
  • Hall of Fame,
    Founding Member
Hello Frank,
the best thing to do is to place an external lan switch even a cheap one.
I'm not sure it works on C3825 but the following is proposed and used on C877 devices:
the idea is to use IRB= integrated routing and bridging.
! routed ports
int f0/0
no ip address
bridge-group 1
int f0/1
no ip address
bridge-group 1
creating a vlan or using default vlan1
int vlan1
no ip address
bridge-group 1
! switch like ports
int f1/0
switchport
swithport mode access
switchport access vlan 1
int f1/1
switchport
int bvi1
! L3 device
ip addr public mask
no shut
bridge 1 protocol ieee
bridge 1 route ip
two notes:
there can be performance penalties
And you close the possibility to future changes: if you need a second ip subnet in the future ?
Hope to help
Giuseppe
iPhrankie Fri, 07/24/2009 - 12:13
Thank you, Giuseppe.
Is their a recommendation on switch speeds?
Since our T3 tops at 45mb would a 100mb switch be enough or would we see a performance gain going with a gigabit switch?
Edison Ortiz Tue, 07/28/2009 - 13:23
  • Hall of Fame,
    Founding Member
A switch will provide faster throughput over a router but you need to take into consideration the features that you will lose by moving from a software based routing solution to a hardware based routing solution.
QoS and NetFlow may be features that you need on a WAN Edge device and low-end switches do not support that.
HTH,
__
Edison.
iPhrankie Tue, 07/28/2009 - 15:56
I've been doing research on this for the last two days on this problem.
I have 4 FastEthernet ports I was hoping to attach 4 devices to.
1. Web Server
2. FTP Server
3. Etc
4. Etc
These particular servers need to face the internet and have public IP addresses.
Based on what I can find, I have two options.
1. Do vlan trunking on the FastEthernet ports.
2. Connect a simple switch to one of the FastEthernet ports and plug the devices into the switch.
I honestly don't know which one will provide better performance.
I'm open to recommendations. Thanks.
Edison Ortiz Tue, 07/28/2009 - 18:56
  • Hall of Fame,
    Founding Member
You don't need to do Vlan trunking on the FastE ports, simply create a L2 Vlan and assign the ports to it.
If you need to route this L2 Vlan with other subnets, simply create a Switch Virtual Interface - assign an IP address and configure the devices on that subnet to point to this IP address as the gateway.
If your needs are small and the 4 ports provides the port density required, a switch won't provide that much speed over the router.
In the original post, you mentioned a T3 and a switch won't support a T3 module hence you still need a router in the picture.
HTH,
__
Edison.
