Error message
  • Unable to create CTools CSS cache directory. Check the permissions on your files directory.
Measuring different protocols utilization
Jul 23rd, 2009
Is there any tools out there to calculate and meaure network measurements from Cisco?
I will like to see the different protocols utilization. It must be easy to configure. Is there any cisco tools out?
Overall Rating: 5 (3 ratings)
leo_zidane Thu, 07/23/2009 - 19:26
Is there any free tools cause i think it need a cost?
Roman Rodichev Thu, 07/23/2009 - 19:30
  • Gold, 750 points or more
Lucien had a great suggestion with NBAR. You can configure NBAR on the router and then do "show ip nbar protocol-discovery" to see results without any external tools.
Configure "ip nbar protocol-discovery" on each interface.
Roman
Lucien Avramov Thu, 07/23/2009 - 19:20
  • Red, 2250 points or more
You can use netflow on the router, that involves to have a nrtflow collector softeare on a server for collection. Cisco has NFC.
You can use NBAR on the device and then collect the statistics over snmp. You could poll that data using freewares such as mrtg.
Those are the 2 ways to monitor protocol utilization.
There is also the nam module that can collect those for you.
leo_zidane Thu, 07/23/2009 - 20:10
Hi lavramov,
For NBar, i have a similar tool that is cacti. But how can i get the statistics over snmp?
Lucien Avramov Thu, 07/23/2009 - 21:27
You can query the NBAR protocol MIB :
CISCO-NBAR-PROTOCOL-DISCOVERY-MIB
It's up to you to configure / customize cacti, mrtg or whatever software you have to poll this MIB.
You can download and read the mib from:
http://tools.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en&step=2
NBAR is better than netflow if you decide to go with freewares.
leo_zidane Thu, 07/23/2009 - 22:36
So i will need to enable on each interface that i want to monitor with this command "ip nbar protocol-discovery"?
Is there any global command for it?
Is there any impact like causing CPU and memory usage high if i will to enable on the core switch every interfaces?
leo_zidane Thu, 07/23/2009 - 23:39
Is it supported on catayst switch?
Cisco firewalls?
So it is impossible to monitor such traffic on switch level itself?
