Disabling x-auth ?
Jul 23rd, 2009
Hi all. I have a hub router running DMVPN and Easy vpn for remote clients. Before DMPVN everything works fine for easyvpn. Then i configured DMVPN and added this command
crypto isakmp key 6 xxxxx address 0.0.0.0 no-xauth.
My DMVPN worked fine but easyvpn failed. As soon as i removed no-xauth from preshared key everything worked fine. Now in my search i went through a doc on this site that addressed this issue but i am confused for 2 points
1) That doc if i am not wrong assumed that both site to site and easyvpn are on the same interface which is not the case here. Easyvpn and DMVPN source interfaces are different.
2) Why is global preshared key affecting easyvpn at all ? i think easyvpn will be looking for the keys defined in its own group config and not global !
Kindly clear my confusion
