07-23-2009 09:59 PM
Hello this is my first ever post, so please bear with me if my tech lingo is below par.
I am very new to Tcl(Tool command language) and I need to create a policy for a CAT6500 to generate a 'syslog snmp-trap strdata "message to server"' when a specific syslog msg occurs. Now I've tried the Applet SNMP_Trap_Generation_Applet which works a treat, however I need to be more specific about which syslog messages get sent to the server.
Here's some pseudo code to try explain what I'm looking for.
::cisco::eem::event_register_syslog pattern .*-SP-.*
# Get the syslog message that caused the event to trigger
array set arr_einfo [event_reqinfo]
set syslog_msg $arr_einfo(msg)
# Check if syslog msg is = "LINK-SP-3" or "LINEPROTO-SP-5"
# If it is exit and don't send to trap to server
# Else
# Send snmp-trap message
if {$syslog_msg = "LINK-SP-3" | $syslog_msg = "LINEPROTO-SP-5" } {
action_syslog msg "blah blah"
exit
}else {
action_syslog snmp-trap strdata "SP log error on Catalyst"
As you can see the pattern .*-SP-.* is what I'm looking for in the syslog however I don't want to generate a snmp-trap for 2 specific patterns "LINK-SP-3" or "LINEPROTO-SP-5".
Any help out there would be great.
Solved! Go to Solution.
07-26-2009 10:56 PM
07-23-2009 10:29 PM
Your pseudo-code is very close. This is what you want:
if { ! [regexp {LINK-SP-3} $syslog_msg] && ! [regexp {LINEPROTO-SP-5} $syslog_msg] } {
action_snmp_trap strdata "SP log error on Catalyst"
07-26-2009 10:22 PM
Thanks jclarke but I just realized that I'm going to need a loop to exclude any other syslog messages in the future. Do you have any idea how I would go about this? Here's some more code to try explain what I need:
# fetch the syslog message that caused the event to trigger
# Build array of error messages
set errLog(1) "LINK-SP-3"
set errLog(2) "LINEPROTO-SP-5"
set errLog(3) "LINEXXX-SP-7"
set errLog(4) "LINEXXX-SP-2"
# Loop through array and compare to syslog_msg
# If msg exists in array set flag to 1
set flag = 0
foreach item $errLog {
if { [regexp {$item} $syslog_msg] } {
set $flag = 1
if {$flag = 0} {
My coding is terrible but I hope you understand what I'm trying to achieve.
07-26-2009 10:31 PM
07-26-2009 10:56 PM
07-26-2009 11:10 PM
Hi thanks for the quick reply. It looks easy the way you have it coded. I have one question, just before the loop there is the line "set found 0" is this necessary? If so could you explain why?
07-26-2009 11:11 PM
No, that line can be removed.
