Lightweight AP usage
Jul 23rd, 2009
Is there a way to find out if the AP is under utilize, over utilize or has reached its maximum load? We can see the controller's CPU and memory usage but there are no such reports for Access Points. Because of this, I was wondering if there is a way to find out if the AP's available bandwidth has reached its limit.
smalkeric Thu, 07/30/2009 - 14:11
With Cisco Unified Wireless Network Software Release 4.2, standalone access points can be viewed on Cisco WCS heat maps. Cisco WCS receives basic status and alarm information and categorizes monitored standalone access points as authorized access points on Cisco WCS heat maps. This helps optimize the WLAN and increase WLAN security. Cisco Aironet standalone access points and selected Cisco integrated services routers access points can be monitored
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps6973/ps8382/prod_brochure0900aecd806b7eae_ps6108_Product_Solution_Overview.html
mat.edwards Thu, 07/30/2009 - 23:59
For a lightweight AP there are several commands that you can use from the WLC to obtain these statistics:
show ap auto-rf {802.11a | 802.11b} Cisco_AP
the above will show you the load for each AP.
Hope this helps.
Mat
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
