ACS Secondary doesn't authenticate
Answered Question
Jul 23rd, 2009
I've setup a secondary ACS, database replication works properly.
But when I try to use secondary ACS server to authenticate user, I can't authenticate successfully.
In Reports and Activity (in secondary ACS), it doesn't appear anything.
In primary ACS, il failed attempts, I can see an "Unknown NAS" from the ip address of the secondary ACS, it seems that secondary try to use primary to authenticate...
Where I'm wrong?
Daniele
Correct Answer by Jagdeep Gambhir about 7 years 10 months ago
Hi Daniele,
That is due to proxy setting on the Secondary acs. On secondary acs please go to acs-->network configuration -->proxy dis table---> Bring your secondary acs under forward to box.
That should fix it.
~JG
Do rate helpful posts
Overall Rating: 5 (1 ratings)
andrewswanson Wed, 07/29/2009 - 06:01
  • Silver, 250 points or more
are you replicating "Network Configuration Device tables" between the two ACS and do your AAA clients appear ok in the Network Configuration section of the second ACS?
hth
andy
ps what ver of ACS?
dimensyssrl Thu, 07/30/2009 - 01:31
yes, I'm replicating all configurations
yes, they appear
ps what ver of ACS?
3.2
Daniele
Correct Answer
Jagdeep Gambhir Wed, 07/29/2009 - 08:30
  • Red, 2250 points or more
Hi Daniele,
That should fix it.
~JG
