how can i make the hsrp/glbp virtual ip send gratuitous-arps?
Jul 23rd, 2009
how can the hsrp/glbp virtual ip send gratuitous-arps?
we found the 3560 switch change the link from 6500 to 4500,hsrp group changed,virtual mac change make the 3560 can't comunication the virtual gateway,must using clear arp in 3560 to re-arp the same virtual gateway's new mac.
Peter Paluch Fri, 07/24/2009 - 00:21
  • Cisco Employee,
This is strange. The virtual MAC address of a HSRP/GLBP group should be stable and should not change if the active router changes.
Please provide us with the following information:
1.) The virtual MAC addresses of the HSRP/GLBP group as created by your 6500 and 4500 routers.
2.) If possible, the configuration of the interface where the standby group is being run.
Best regards,
Peter
