Monitoring VPN
Jul 24th, 2009
Hi, we have several Site-to-Site VPN's and IPSec Tunnel for our sites and Remote users terminating on our PIX 515's and ASA. Is there a way to proactively monitor these tunnels so that troubleshooting can be expedited using SNMP, traps, etc
Pls help.
Rgds,
Satya
merabtavart Fri, 07/22/2011 - 01:56
Check
http://www.vpnttg.com/
Advantage   of VPNTTG over other SNMP based monitoring software’s is  following:   Other (commonly used) software’s are working with static OID  numbers,   i.e. whenever tunnel disconnects and reconnects, it gets  assigned a  new  OID number. This means that the historical data, gathered  on the   connection, is lost each time. However, VPNTTG works with VPN  peer’s  IP  address and it stores for each VPN tunnel historical  monitoring  data  into the SQL server and into the RRD (Round Robin  Database) file.
