wae inline mode and routing problem
Jul 24th, 2009
My network topology is :
multiple Network - Backbone router - routing network (with multiple router) - WAE - Access Router - Leased Line - Access Router - WAE - Routing network (with multiple router) - backbone router - multiple network
how you configure static route and default static route?
on diagnostic report (Wae) Asymetric routing is seen in the device....
best regards..
gmarogi Thu, 07/30/2009 - 17:07
  • Bronze, 100 points or more
Inline mode and WCCP redirection are exclusive. You cannot configure inline mode if the WAE is configured for WCCP operation. Inline mode is the default mode when the Cisco WAE Inline Network Adapter is installed in a WAE device. In inline mode the WAE physically and transparently intercepts traffic between the clients and the router. To use this mode, you must use a WAE with the Cisco WAE Inline Network Adapter installed.
