Problems with "Conditional Web Redirect " on WISM 6.0.182.0
Jul 24th, 2009
Has anyone been able to successfully use this feature? My freeradius setup looks like this:
xxxx Cleartext-Password := "xxx"
Fall-Through = No,
cisco-avpair = "url-redirect=http://mrtg.uio.no"
The Radius part seems to be working, once I've authenticated with 802.1X and open Firefox I'm redirected to http://$url-from-radius/?switch_url=https://$ip-address-on-virtual-interface... My browser is then redirected to a new url, which is the old url concatenated with "http://$url-from-radius/?switch_url=https://$ip-address-on-virtual-interface..". After some time the redirection stops, the URL is then some 900 characters in length - looks like Firefox gives up. I've tried with Opera and Internet Explorer as well, the problems are somewhat similar.
Thanks for any tips/hints.
-Øystein
weterry Fri, 07/24/2009 - 19:35
  • Silver, 250 points or more
I helped someone last week with the Splash Page, which is basically conditional web redirect without any conditions. And it worked like a charm with the cisco-avpair "url-redirect=http://www.cisco.com"
Are you actually doing this redirect for specific conditions? OR are you just trying to do a Web passthrough with 802.1x? If the latter, try the "splash page" configuration and see if it works with the your av-pair url-redirect....
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
