Limiting management access to ASA
Jul 24th, 2009
Hi! How to limit access to management console (even demo) via ASDM etc. Conf -> DevMan -> Management Access ... I try set host info, but ... failed. Yes, with subnet is OK. Probably I missed something! More thanks, Alar.
Collin Clark Fri, 07/24/2009 - 05:24
  • Purple, 4500 points or more
What's the error? That is where it's done and you can set just a host.
Alar Pandis Fri, 07/24/2009 - 07:14
Hi and thanks!
When I enter host ip address and mask and OK then ... "The Network address is not valid." error appear. Probably I enter something wrong, I mean, there must be something else/more, I'm not sure, but can't enter host address. Network address entering does work. Probably I missed something. More thanks, Alar.
Collin Clark Fri, 07/24/2009 - 07:26
What's the subnet mask you're entering? It should be 255.255.255.255.
Alar Pandis Fri, 07/24/2009 - 07:31
Oh, yes! My mistake, as I thought! I'd enter all the time resp. subnet mask.
More thanks!
Alar.
