Temporarily remove VPN authentication
Jul 24th, 2009
I know this is a dangerous proposition - but we had a problem with our ACS server that prevented remote access VPN users authenticating via VPN.
Is it possible to temporarily remove authentication for VPN session's when/if this problem reoccurs?
Collin Clark Fri, 07/24/2009 - 08:05
Under the group policy there is a command user-authentication disable. I have not used it before, but it sounds like what you're looking for.
Hope it helps.
