LMS 3.2 - Creating Poller it gets stucked while fetching instance info
Jul 24th, 2009
Hi there,
while creating a poller for your routers I discovered a problem with fetching the instances
No.Routers , about 200
The problem is that the "discovery" doesn't show where it get stuck and which devices are affected.
This is same problem since HUM 1.1.
Are there any log-files showing the faulty devices to better troubleshoot it?
Thanks for any feedback
Joe Clarke Fri, 07/24/2009 - 09:06
The upm_process.log and upm_ui.log will have details about any problems configuring pollers. The same is true in HUM 1.1 and 1.2.
