side-to-side vpn only comunicating in one direction
Jul 24th, 2009
Hi all together,
My problem is that I have a running vpn connection between cisco asa 5505 and a LANCOM 1711 VPN that is only letting traffic through in one direction. Meaning I can ping and act via Windows RDP from the net behind the Cisco (net 192.168.115.0/255.255.255.0) to the LANCOM-net (192.168.0.0./255.255.255.0) but it is not working in the other direction.
On the Cisco net there has been used an other LANCOM before und the VPN was working without problems. We now just took the configuration and fixed it to the Cisco.
And as the tunnel is established I do not see the reason why the LANCOM packages do not come though. In the Syslog of the Cisco there is no reaction.
Can anybody help?
NadineMeins Sun, 07/26/2009 - 23:10
Hi!
Thx for replying.
This is my configuration:
Saved
ASA Version 8.2(1)
hostname ASABrandsDEBU
domain-name brands.local
enable password fuuwAM47BOb7KkRB encrypted
passwd 906qOuTz0f2InvIK encrypted
names
name 85.112.230.6x Internet description Internet
name 192.168.116.96 VPN-makeIT description VPN-makeIT
name 192.168.115.10 SRV-BrandsS01 description SRV-BrandsS01
name 192.168.115.30 SRV-BrandsS03 description SRV-BrandsS03
name 192.168.115.25 SRV-Testserver description SRV-Testserver
name 217.146.152.10x GW-INTEX description GW-INTEX
name 62.153.136.22x GW-Martinnet description GW-Martinnet
name 62.72.79.19x GW-Muenster description GW-Muenster
name 213.76.140.222 GW-Polen description GW-Polen
name 192.168.115.0 NW-Buchholz description NW-Buchholz
name 192.168.114.0 NW-DMZ description NW-DMZ
name 192.168.0.0 NW-Muenster description NW-Muenster
name 192.168.19.0 NW-Polen description NW-Polen
name 192.168.117.96 VPN-Brands-Admin description VPN-Brands-Admin
name 192.168.120.96 VPN-Brands-CM description VPN-Brands-CM
name 192.168.118.96 VPN-Brands-GS description VPN-Brands-GS
name 192.168.119.96 VPN-Brands-Sales description VPN-Brands-Sales
name 192.168.121.96 VPN-Extern description VPN-Extern
name 194.49.23.0 NW-INTEX description NW-INTEX
name 212.185.56.0 NW-Martinnet description NW-Martinnet
interface Vlan1
nameif inside
security-level 100
ip address 192.168.115.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 85.112.230.12x 255.255.255.252
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
ip address 192.168.114.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 3
boot system disk0:/asa821-k8.bin
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns domain-lookup inside
dns domain-lookup outside
dns domain-lookup dmz
dns server-group DefaultDNS
same-security-traffic permit intra-interface
object-group network DM_INLINE_NETWORK_1
network-object NW-Muenster 255.255.255.0
network-object host GW-Muenster
object-group network DM_INLINE_NETWORK_2
access-list makeIT_splitTunnelAcl standard permit NW-Buchholz 255.255.255.0
access-list inside_nat0_outbound extended permit ip NW-Buchholz 255.255.255.0 VPN-makeIT 255.255.255.240
access-list inside_nat0_outbound extended permit ip NW-Buchholz 255.255.255.0 VPN-Brands-Admin 255.255.255.240
access-list inside_nat0_outbound extended permit ip NW-Buchholz 255.255.255.0 VPN-Brands-GS 255.255.255.240
access-list inside_nat0_outbound extended permit ip NW-Buchholz 255.255.255.0 VPN-Brands-Sales 255.255.255.240
access-list inside_nat0_outbound extended permit ip NW-Buchholz 255.255.255.0 VPN-Brands-CM 255.255.255.240
access-list inside_nat0_outbound extended permit ip NW-Buchholz 255.255.255.0 VPN-Extern 255.255.255.240
access-list inside_nat0_outbound extended permit ip NW-Buchholz 255.255.255.0 NW-Polen 255.255.255.0
access-list inside_nat0_outbound extended permit ip NW-Buchholz 255.255.255.0 NW-Martinnet 255.255.255.0
access-list Brands-Admin_splitTunnelAcl standard permit NW-Buchholz 255.255.255.0
access-list Brands-GS_splitTunnelAcl standard permit NW-Buchholz 255.255.255.0
access-list Brands-Sales_splitTunnelAcl standard permit NW-Buchholz 255.255.255.0
access-list Brands-CM_splitTunnelAcl standard permit NW-Buchholz 255.255.255.0
access-list Extern_splitTunnelAcl standard permit NW-Buchholz 255.255.255.0
access-list outside_cryptomap extended permit ip NW-Buchholz 255.255.255.0 NW-Muenster 255.255.255.0
access-list outside_2_cryptomap extended permit ip NW-Buchholz 255.255.255.0
NadineMeins Sun, 07/26/2009 - 23:11
access-list outside_3_cryptomap extended permit ip NW-Buchholz 255.255.255.0 NW-INTEX 255.255.255.0
access-list outside_4_cryptomap extended permit ip NW-Buchholz 255.255.255.0 NW-Martinnet 255.255.255.0
access-list outside_access_in extended permit icmp any any log notifications
access-list outside_access_in extended permit ip object-group DM_INLINE_NETWORK_1 NW-Buchholz 255.255.255.0
access-list outside_access_in extended permit udp object-group DM_INLINE_NETWORK_2 NW-Buchholz 255.255.255.0
access-list outside_cryptomap_1 extended permit ip NW-Buchholz 255.255.255.0 NW-Muenster 255.255.255.0
access-list outside_cryptomap_2 extended permit ip NW-Buchholz 255.255.255.0 NW-Muenster 255.255.255.0
access-list inside_nat0_outbound_1 extended permit ip NW-Buchholz 255.255.255.0 NW-Muenster 255.255.255.0
pager lines 24
logging enable
logging asdm informational
no logging message 302021
no logging message 302020
mtu inside 1500
mtu outside 1500
mtu dmz 1500
ip local pool makeIT 192.168.116.100-192.168.116.110 mask 255.255.255.0
ip local pool VPN-Brands-Admin 192.168.117.100-192.168.117.110 mask 255.255.255.0
ip local pool VPN-Brands-GS 192.168.118.100-192.168.118.110 mask 255.255.255.0
ip local pool VPN-Extern 192.168.121.100-192.168.121.110 mask 255.255.255.0
ip local pool VPN-Brands-Sales 192.168.119.100-192.168.119.110 mask 255.255.255.0
ip local pool VPN-Brands-CM 192.168.120.100-192.168.120.110 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-621.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 0 access-list inside_nat0_outbound_1 outside
nat (inside) 1 0.0.0.0 0.0.0.0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 85.112.230.125 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
NadineMeins Sun, 07/26/2009 - 23:13
http server enable
http NW-Buchholz 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 match address outside_cryptomap_2
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer GW-Muenster
crypto map outside_map 1 set transform-set ESP-3DES-MD5 ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 set security-association lifetime seconds 43200
crypto map outside_map 1 set security-association lifetime kilobytes 200000
crypto map outside_map 1 set reverse-route
crypto map outside_map 2 match address outside_2_cryptomap
crypto map outside_map 2 set pfs
crypto map outside_map 2 set peer GW-Polen
crypto map outside_map 2 set transform-set ESP-3DES-MD5
crypto map outside_map 2 set security-association lifetime seconds 2013
crypto map outside_map 2 set security-association lifetime kilobytes 200000
crypto map outside_map 3 match address outside_3_cryptomap
crypto map outside_map 3 set pfs group5
crypto map outside_map 3 set peer GW-INTEX
crypto map outside_map 3 set transform-set ESP-AES-128-MD5
crypto map outside_map 3 set security-association lifetime seconds 3600
crypto map outside_map 3 set security-association lifetime kilobytes 200000
crypto map outside_map 4 match address outside_4_cryptomap
crypto map outside_map 4 set pfs
crypto map outside_map 4 set peer GW-Martinnet
crypto map outside_map 4 set transform-set ESP-AES-128-MD5
crypto map outside_map 4 set security-association lifetime seconds 3600
crypto map outside_map 4 set security-association lifetime kilobytes 200000
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash md5
group 2
lifetime none
telnet NW-Buchholz 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
group-policy Brands-GS internal
group-policy Brands-GS attributes
dns-server value 192.168.115.14 192.168.115.7
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value Brands-GS_splitTunnelAcl
default-domain value brands.local
NadineMeins Sun, 07/26/2009 - 23:15
group-policy Brands-Sales internal
group-policy Brands-Sales attributes
split-tunnel-network-list value Brands-Sales_splitTunnelAcl
group-policy Brands-CM internal
group-policy Brands-CM attributes
split-tunnel-network-list value Brands-CM_splitTunnelAcl
group-policy Brands-Admin internal
group-policy Brands-Admin attributes
split-tunnel-network-list value Brands-Admin_splitTunnelAcl
group-policy DfltGrpPolicy attributes
vpn-filter value Brands-Sales_splitTunnelAcl
group-policy makeIT internal
group-policy makeIT attributes
split-tunnel-network-list value makeIT_splitTunnelAcl
group-policy Extern internal
group-policy Extern attributes
split-tunnel-network-list value Extern_splitTunnelAcl
username system password gC7MwUUDUbHTlU48 encrypted privilege 15
username makeIT password ZBxNX0An9ytNgYIf encrypted privilege 0
username makeIT attributes
vpn-group-policy makeIT
username s.behrendt password l1rPzoB4p6dBQwin encrypted
username s.behrendt attributes
group-lock value Brands-Sales
service-type remote-access
tunnel-group makeIT type remote-access
tunnel-group makeIT general-attributes
address-pool makeIT
default-group-policy makeIT
tunnel-group makeIT ipsec-attributes
pre-shared-key *
tunnel-group Brands-Admin type remote-access
tunnel-group Brands-Admin general-attributes
address-pool VPN-Brands-Admin
default-group-policy Brands-Admin
tunnel-group Brands-Admin ipsec-attributes
pre-shared-key *
tunnel-group Brands-GS type remote-access
tunnel-group Brands-GS general-attributes
address-pool VPN-Brands-GS
default-group-policy Brands-GS
tunnel-group Brands-GS ipsec-attributes
pre-shared-key *
tunnel-group Brands-Sales type remote-access
tunnel-group Brands-Sales general-attributes
address-pool VPN-Brands-Sales
default-group-policy Brands-Sales
tunnel-group Brands-Sales ipsec-attributes
pre-shared-key *
tunnel-group Brands-CM type remote-access
tunnel-group Brands-CM general-attributes
address-pool VPN-Brands-CM
default-group-policy Brands-CM
tunnel-group Brands-CM ipsec-attributes
pre-shared-key *
tunnel-group Extern type remote-access
tunnel-group Extern general-attributes
address-pool VPN-Extern
default-group-policy Extern
tunnel-group Extern ipsec-attributes
pre-shared-key *
tunnel-group 62.72.79.19x type ipsec-l2l
tunnel-group 62.72.79.19x ipsec-attributes
pre-shared-key *
isakmp keepalive disable
tunnel-group 213.76.140.22x type ipsec-l2l
tunnel-group 213.76.140.22x ipsec-attributes
pre-shared-key *
tunnel-group 217.146.152.10x type ipsec-l2l
tunnel-group 217.146.152.10x ipsec-attributes
pre-shared-key *
tunnel-group 62.153.136.22x type ipsec-l2l
tunnel-group 62.153.136.22x ipsec-attributes
pre-shared-key *
tunnel-group GW-Muenster type ipsec-l2l
tunnel-group GW-Muenster ipsec-attributes
pre-shared-key *
peer-id-validate nocheck
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
NadineMeins Sun, 07/26/2009 - 23:20
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:469d3ac0a382f10168df95e82daf916a
: end
In addition: The problems I have wit NW-Muenster and GW-Muenster. The others have not been tested jet. NAT-T is enabled.
Thanks a lot!
Nadine
