Problem loading unity on new MCS-7825-H4 server
Hey all,
I was wondering if anyone has run into loading unity on a new MCS-7825-H4 server.
I have tried loading it with the provided DVD and it looks like it is installing correctly.
It gets to where it needs to configure the raid controller with this messsage:
CAUTION
SATA RAID is not enabled in your system.
If you continue SATA RAID will be enabled and any pre-existing
software and data will be deleted.
Press Yes to continue or No to Exit
I have clicked yes to continue 4 times now and it just reboots and goes through the process again and gives me the same message.
Anyone seen this? i do have a tac case open. Thought i would run it by here as well..
thanks
Ken
supportipsilan Mon, 07/27/2009 - 01:19
Hi all,
I have a problem with the same server. I want to instal Unity connection 7 with DVD Cisco Unified Communication Manager 7. The wizard asked me to instal drivers. But i don't know which drivers i can instal.
