How to trigger a Syslog message when Multilink bundle changes.
Jul 24th, 2009
Is there a way to configure a router to trigger a Syslog message when a link drops (or joins) a Multilink bundle? For the moment I have CiscoWorks monitoring the physical interfaces in each Multilink bundle, but because of this I have to create a separate Syslog monitor for every Multilink router.
Collin Clark Fri, 07/24/2009 - 08:18
You can view the supported traps with snmp-server enable traps ? command. I don't see anything for multilink, but your router may be different.
jay_finley@cent... Fri, 07/24/2009 - 12:37
My routers are no different, but thanks anyway.
Anyone else know of a method to get the router to trigger a Syslog message when a link joins or leaves a Multilink bundle?
