Unity Connection 7 -hardrive question
Jul 24th, 2009
if i have 2-80GB hardrives for a 7825-H2 server, can i put them into an 7825-H3 server, configure it for Unity Connection, pull the drives out and put them into the 7825-H2 server with no issues?
Tommer Catlin Fri, 07/24/2009 - 08:45
  • Green, 3000 points or more
You can try, but the hardware is different between the H2 and H3. The Linux platform may not like the configuration it built when it loaded on the H2 and now you are an H3. Worth a shot, but kind of like Windows, it needs to the correct drivers to work and the system may not even boot.
Try it and see, let us know!
