CSS Routing
Jul 24th, 2009
We are currently having an issue with our CSS packets. I have a single CSS (11503) that redirects web traffic between two servers for PeopleSoft and WebLogic configurations. We are receiving socket errors on the WebLogic side that the servers are trying to connect to the main IP address of 10.1.1.24. Here is the error message on the server side.
<Mar 21, 2009 10:38:14 AM EDT> <Error> <Socket> <BEA-000403> <IOException occurred on socket: Socket[addr=/10.1.1.24,port=10104,localport=8080]
java.net.SocketException: Connection refused.
at java.net.SocketInputStream.socketRead0(Native Method)
at java.net.SocketInputStream.read(SocketInputStream.java:129)
at weblogic.socket.SocketMuxer.readReadySocketOnce(SocketMuxer.java:826)
at weblogic.socket.SocketMuxer.readReadySocket(SocketMuxer.java:802)
at weblogic.socket.DevPollSocketMuxer.processSockets(DevPollSocketMuxer.java:120)
The clients are connecting using a redirected URL and are connecting fine. These errors occure in random sequence and the retries seem to go through. We feel this may be causing a performance issue on the client side and need to have this resolved. This is an entirely switched network all on the same subnet of 10.1.x.x. Here is the configuration of the CSS box with the relevant config for the servers.
!Active version: sg0750103
configure
!*************************** GLOBAL ***************************
bridge spanning-tree disabled
ip route 0.0.0.0 0.0.0.0 10.1.1.100 1
!************************* INTERFACE *************************
interface 1/1
bridge vlan 10
!************************** CIRCUIT **************************
circuit VLAN10
description "Internal CSS"
ip address 10.1.1.24 255.255.0.0
!************************** SERVICE **************************
service ps90prod-redirect
ip address 10.1.50.115
type redirect
keepalive type none
no prepend-http
redirect-string "//psprod.kichler.net:8080/cfs90pr/signon.html"
active
service ps90prod-redirect2
ip address 10.1.50.85
type redirect
keepalive type none
no prepend-http
active
service ps90prod3
keepalive port 8080
keepalive type tcp
keepalive maxfailure 2
keepalive frequency 3
active
service ps90prod4
keepalive port 8080
keepalive type tcp
active
!*************************** OWNER ***************************
owner ps90prod
content rule-prod
vip address 10.1.52.53
add service ps90prod3
add service ps90prod4
advanced-balance arrowpoint-cookie
url "/*"
protocol tcp
port 8080
active
content rule-prod-redirect
protocol tcp
add service ps90prod-redirect
url "//psprod.kichler.net/"
add service ps90prod-redirect2
port 80
active
content rule-prod2
protocol tcp
active
!*************************** GROUP ***************************
group ps90prod
add destination service ps90prod3
add destination service ps90prod4
active
Gilles Dufour Wed, 07/29/2009 - 03:01
could it be an idle timeout issue.
Try to configure 'flow-timeout-multiplier 50' under each content rule.
Gilles.
tostrander Wed, 07/29/2009 - 09:09
That did not work. We are still seeing the errors on the server side.
Truncated. see log file for complete stacktrace
a.veschak Wed, 09/08/2010 - 12:09
Gilles,
I am facing similar issue... but I see no resolution in this thread.
I see tostrander tried flow-timeout-multiplier and did not help.
Any other thoughts?
-Adam
