show interface counters wrap around?
Jul 24th, 2009
Do the show interface counters wrap around at 2^32-1?
yjdabear Fri, 07/24/2009 - 09:17
AFAIK, the "show interface" counters are not based on the equivalent SNMP MIB values. The formers are cleared by reboots or by manual actions. The latters wrap around depending on what size of counters they are (e.g. The one you quoted is for 32-bit MIB counters.) If "show interface" counters wrap around automatically like MIB values, we'd see far fewer outputs of: Last clearing of "show interface" counters never.
steve.dutky Fri, 07/24/2009 - 13:08
Thank you both for the helpful information for the snmp ifMIB.
Specifically, I need to find out when the show interface counters for input and output packets overflow.
These two apparently do not correspond to any ifMIB variables.
Thanks again.
