Can I connect a 10GBASE X2 to an SFP in a Cisco TwinGig Converter Module
dan_track
I want to know can I connect two 3750-e switches together via an SFP in a 10GBASE X2? Will it work? and will it communicate at gig?
Dan
13 Replies 13
jbrenesj
Level 3
Level 3
It will work just as connecting two switches with a copper cable but you'll get up to 10G speeds. Of course it would be better to connect both 3750E using the stackwise cable because you will get up 64G in a dual stack ring
Thanks for that. Given that one end is an SFP in the twin Gig govertor i.e with LC connection on the fibre cable and the other is in the 10GBase X2 with an SC connector on the Fibre cable, won't it only run at 1Gig max?
Dan
Hi, on the SFP side what do you have, SX (GLC-SX-MM) or LX (GLC-LH-SM)?
On the 10G side what is the X2 model?
You are going to have a problem connecting these but please let me know the info above so I can explain further
Thanks for the reply. I've got myself stuck in position and am hoping I can get out of it by connecting these two together:
1) Twin gig has GLC-SX-MM=
2) Cisco X2-10GB-SR
I'm hoping this is going to work with 62.5/125 micron Multimode Fiber cable. Please let me know if this will work?
Dan
Unfortunately these two can't connect because of the wavelenght of the signal.
They are totally different so the X2 won't see the SFP signal.
Even when the physical fiber is OK, the SFP and X2 are totally different technologies and the link will remain down/down.
Basically you need to match the connector on both ends of the link, either one GLC-SX-MM at each end or one X2 at each end
:( T'is a sad day indeed for me. Silly me ordered an SC-LC cable and now can't think how I can get out of this mess? Any thoughts on possibilities?
Dan
How long is distance between the two devices? Fiber patch cords are not very expensive
Reza
Dan,
Speed mismatch.
The link will not come up.
You have to do 10Gig SC to SC or 1Gig LC to LC
Reza
What is you main problem here? Distance between both switches?
The problem is that with a fiber link you need to have the same technology at each end
The two ends of the fibre are different one side is sc and the other is LC. I can't connect the two 3750-e stacks together as the 10G modules only take SC while the SFP only takes LC. I do have another 10G module but since the other end of the fibre is LC I can't connect it.
Any bright ideas on what I can do. The two stacks are in two differnet racks about 3 metres apart from each other.
Dan
If the other 10G module is also a X2-10GB-SR then just get a fiber cable but if it's a different model then it will never connect with the X2-10GB-SR.
As a rule you "need to have the same module model on each end"
Looks like I'll have to. The problem is that tomorrow I need to join the two switches and I forgot to order the sc-sc cable, so I was looking for someway around the problem.
Thanks for your help though.
Dan
Dan,
If you have patch panels with right connectors, you could do SC (switch) to LC and LC back to SC (switch)
Reza
