Change minimum PIN length in CUCMBE
Jul 24th, 2009
  • Bronze, 100 points or more
I've got CUCMBE 7 with LDAP integration. When users on Unity conneciton are asked to change their PIN it allows them a minimum length of 1. I want this to be 4. Where do I change this?
Thanks.
Hoan Mai Fri, 07/24/2009 - 13:57
  • Cisco Employee,
Try this -
CUCA>System Settings>Authentication Rules>Recommended Voice Mail Authentication Rule
Rick Mai
shh5455 Fri, 07/24/2009 - 14:00
Hmm... I don't have that in my system settings menu. What version are you on? I'm using 7.0.2.
Hoan Mai Fri, 07/24/2009 - 14:56
  • Cisco Employee,
Oops my bad. This is for UC standalone.
For BE, you need to setup the user setting on the CM side.
Create a new Credential Policy under User management > Credential Policy.
Apply the policy to the end user by editing the PIN tab.
