Can the information in subnet based groups be put into a report?
alukes
Topology services>Topology Groups>Campus@>system defined groups>subnet based groups
This is a list of subnets. When the subnet is clicked, the devices using that subnet are listed.
Is there a way to generate a report of all subnets with the corresponding devices?
Is there some sort of database somewhere in Ciscoworks that could be accessed to do this?
We want to create a database of our subnets and where they are used.
No, it simply means that an associated VLAN/VTP domain could not be found for that subnet. This can happen on, for example, loopback interfaces, or interfaces which are down, or not connected into managed switch ports.
These files are a big help.
Just a few questions. What does it mean when the VLAN and VTP are blank in the router database?
Does that mean there will be problems properly displaying some VTP clouds?
If so how do I get these fields populated?
