trying to configure an Async port on a 1760
garyrivers
is there a difference in the way async ports are configured between 1800 and 1700 RTRs?
i have 3 remote 1800 RTRs that have a dialup backup link via a modem connected to the AUX port.
they work great.
so now i'm tasked with doing the same with a 1760 RTR.
well, thinking that a 1760 SHOULDN'T be that much different than a 1800 i pasted an 1800 config into the 1760.
everything works except the ASYNC port will not accept the " dialer-group 1" cmd.
i'm getting this msg:
"Remove Dialer Profile Configuration first" when i insert the cmd.
here's the RTR config
version 12.4
service password-encryption
service sequence-numbers
hostname Colwich_TX_RTR
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable password 7 0822455D0A16
no aaa new-model
clock timezone central -5
ip cef
no ip domain lookup
ip domain name kbsad.local
ip name-server 10.30.47.4
ip sla monitor 9
type echo protocol ipIcmpEcho 10.30.13.25
timeout 1000
threshold 2
frequency 3
ip sla monitor schedule 9 life forever start-time now
frame-relay switching
chat-script Dialout ABORT ERROR ABORT BUSY "" "AT" OK "ATDT \T" TIMEOUT 30 CONNECT \c
modemcap entry MY_USR_MODEM:MSC=&F1S0=1
username grivers privilege 15 password 7 082A5B4D014857
username tcrane privilege 15 password 7 082A5B4D014857
track 122 rtr 9 reachability
interface Loopback0
ip address 10.254.253.6 255.255.255.255
interface FastEthernet0/0
description Connection to KWCH
ip address 10.30.13.28 255.255.255.248
speed auto
full-duplex
interface Serial0/0
no ip address
shutdown
no fair-queue
interface Ethernet1/0
description Colwich Xmitter LAN
ip address 10.30.50.254 255.255.255.0
ip helper-address 10.30.40.0
no ip route-cache cef
no ip route-cache
full-duplex
interface Async5
no ip address
encapsulation ppp
no ip route-cache
dialer in-band
dialer pool-member 1
async mode interactive
routing dynamic
interface Dialer1
ip address negotiated
no ip redirects
encapsulation ppp
no ip route-cache
dialer pool 1
dialer remote-name KWCH_RTR
dialer string 98324031
dialer-group 1
router eigrp 1
network 10.0.0.0
auto-summary
ip route 10.30.40.0 255.255.248.0 10.30.13.25 track 122
ip route 0.0.0.0 0.0.0.0 10.30.13.25
ip route 10.30.40.0 255.255.248.0 Dialer1 100
ip http server
ip http authentication local
no ip http secure-server
logging history informational
logging 10.30.41.60
access-list 102 permit ip any any
access-list 103 permit ip any any
dialer-list 1 protocol ip list 102
snmp-server community KWCHnet RO
snmp-server location CW Site
snmp-server contact KWCH IT Dept
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps syslog
snmp-server enable traps rtr
snmp-server host 10.30.41.60
control-plane
banner login ^CC WELCOME TO THE COLWICH TX ROUTER ^C
line con 0
exec-timeout 15 0
password 7 15191C0F0C
login local
line aux 0
password 7 1511021F0725
script dialer Dialout
login
modem InOut
modem autoconfigure type MY_USR_MODEM
transport input all
transport output all
autoselect during-login
autoselect ppp
speed 115200
flowcontrol hardware
line vty 0 4
exec-timeout 15 0
password 7 000F04050C
login local
line vty 5 15
exec-timeout 15 0
password 7 104D000A0618
login
ntp clock-period 17208463
ntp server 10.30.46.155
end
Any thoughts?
Thanks, Gary
slmansfield
Level 4
Level 4
You already have a "dialer-group 1" statement under your Dialer1 interface. I think it's telling you that when you try to add a second one under the async interface.
slmansfield
Level 4
Level 4
okay, i'll take a look at that.
