Problem vpn Pix - Firewall nokia
Jul 24th, 2009
I have a tunnel vpn between a firewall pix 7.24 and a firewall nokia at other company.
I managing the frewall pix and another company the firewall nokia.
In the pix I have the following messages:
with the command:
sh crypto isakmp sa
1 IKE Peer: 1.1.1.4
Type : L2L Role : responder
Rekey : no State : MM_REKEY_DONE_H2
2 IKE Peer: 1.1.1.4
Rekey : yes State : MM_ACTIVE_REKEY
When it works properly show the following message
1 IKE Peer: 1.1.1.4
Type : L2L Role : initiator
Rekey : no State : MM_ACTIVE
What I can do to solve the problem?
ivillegas Thu, 07/30/2009 - 15:10
  • Silver, 250 points or more
Check that you are not doing the extended ping. Asa does not permit extended pings and you will have to actually pass traffic through the asa from any device connected on the inside for it to encrypt the traffic.
