Same BGP AS usable in disconnected Internet Networks?
Hello, I have a scenario to explore, regarding using the same AS number for a different deployment of BGP. I will simplify it for discussion.
Scenario: Two routers, one at each internet-connected site, both running BGP to the ISP, using the same AS number. These routers are running different “internal” /24 networks, which will be announced to the internet. These two routers are _NOT_ connected to each other via some sort of backbone, or private WAN circuit. Can I use the same AS number for both BGP deployments? Any config guidance you can provide is appreciated.
NOTE: Internal networks = public network local to each sites internet presence.
Danilo Dy Fri, 07/24/2009 - 19:41
Yes you can use same ASN for two sites with different network.
If you want both sites to reach each other thru internet;
1. If you are receiving full routes from your ISP, you have to configure them with the "allowas-in".
2. If you only received default route from your ISP, it should be fine.
