Help with brand new IP Phone 7941G
cduance83
I have bought a brand new phone as above. I have it currently connected to a POE switch which is fine. It has power but it is constantly saying Configuring IP in the botttom left. I am not sure how to set the correct time and date or the correct time zone/location. I have been tralling the web for a few hours now and I would just like a step by step guide to configure my phone. Many thanks Charles
Jaime Valencia
As there's no version or mention if this is CUCM or CME, i'll go with CUCM 7.X
You configure the timezone under:
Date/Time Group Configuration
Then you make reference to it in the Device Pool and assign the DP to the phone.
java
if this helps, please rate
java
I this the OP has no CM or CME and expects the phone to work like one of the SIP devices.
Unfortunately, that is not possible.
