Support for Cos per access on 7206 as PE
Jul 25th, 2009
We are exploring the possibility of configuring QOS policies for the main interface, which has multiple sub-interfaces. I want to know if a common policy applied on the main interface will be applicable to the subinterfaces too. This makes all layer 2 connections under the interface subject to the QoS policy. Each class within the policy will operate on the aggregate class traffic across all the layer 2 connections. If the Qos policy is at the full interface rate then a single tier policy can be applied directly to the main interface. If the required speed is less than the interface then a hierarchical policy can be applied. In the output direction and parent policy and a child policy are constructed. The child policy matched on each of the Qos classed and provided the necessary treatment. The parent policy is applied to the main interface. IT matched on the default class (i.e. all traffic), applied a shaper to limit the output bandwidth and also is where the child policy is applied. In the inbound direction the same structure is repeated except in this case the parent policy used a policer rather than a shaper.
Laurent Aubert Sun, 07/26/2009 - 11:49
  • Cisco Employee,
Applying a service-policy on the main interface provides a shared QoS policy for all the subinterfaces. If you have a class for IPP 5 for example, all the IPP 5 traffic send over all the subinterfaces will be in the same queue.
Laurent.
adarsh Tue, 07/28/2009 - 17:29
Thanks! Laurent for your response, however things are still unclear to me. Let me elaborate it in context of my original post. Not sure if the following configs (for policy and interface) is supported on Cisco platform (7200 preferably):
Given below is the sample of policy and interface config:
POLICY CONFIG:
class-map nni_mgmt_input
match access-group 122
class-map match-any nni_ef_input
match ip prec 5
class-map match-any nni_af4_input
match ip prec 3
class-map match-any nni_ef_output
match qos-group 4
class-map match-any nni_af_output
match qos-group 6
match access-group 124
match access-group 123
policy-map NNI-IN-test
description CPA policy map to apply to main NNI interface inbound with remarking
class nni_mgmt_input
police 8000 8000 8000 conform-action set-mpls-exp-transmit 6 exceed-action set-mpls-exp-transmit 6
class nni_ef_input
set ip dscp ef
police 2600000 8000 8000 conform-action set-mpls-exp-transmit 4 exceed-action drop
class nni_af4_input
set ip dscp af41
class class-default
set ip dscp 0
police 8000 8000 8000 conform-action set-mpls-exp-transmit 5 exceed-action set-mpls-exp-transmit 5
policy-map NNI-PIN-test
class class-default
police 20416000 81600 163200 conform-action transmit exceed-action drop
service-policy NNI-IN-test
policy-map NNI-OUT-test
description Outbound CPA child policy for NNI gateway
class nni_ef_output
police 2600000 8000 8000 conform-action set-dscp-transmit 40 exceed-action drop
priority 2600 8000
class nni_af_output
bandwidth 3568
police 8000 8000 8000 conform-action set-dscp-transmit 24 exceed-action set-dscp-transmit 24
random-detect dscp-based
random-detect exponential-weighting-constant 10
random-detect dscp 24 141 226 10
class class-default
bandwidth 13432
police 8000 8000 8000 conform-action set-dscp-transmit 8 exceed-action set-dscp-transmit 8
random-detect exponential-weighting-constant 9
random-detect dscp 8 70 186 5
policy-map NNI-POUT-test
class class-default
shape average 20400000 81600
service-policy NNI-OUT-test
INTERFACE CONFIG
interface GigabitEthernet0/1
dampening
no ip address
load-interval 30
media-type rj45
speed 1000
duplex full
no negotiation auto
no cdp enable
no clns route-cache
service-policy input NNI-PIN-test
service-policy output NNI-POUT-test
interface GigabitEthernet0/1.2
encapsulation dot1Q 2
ip vrf forwarding vrfCPPCtesting2
ip address x.x.x.x
no cdp enable
interface GigabitEthernet0/1.3
encapsulation dot1Q 3
ip vrf forwarding vrfCPPCtesting3
ip address x.x.x.x
no cdp enable
interface GigabitEthernet0/1.4
encapsulation dot1Q 4
ip vrf forwarding vrfCPPCtesting4
ip address x.x.x.x
no cdp enable
interface GigabitEthernet0/1.5
encapsulation dot1Q 5
ip vrf forwarding vrfCPPCtesting5
ip address x.x.x.x
no cdp enable
Laurent Aubert Wed, 07/29/2009 - 07:07
  • Cisco Employee,
I don't see any issue so next step is to test it may be with the last release to have the latest QoS feature ;-)
Laurent.
adarsh Wed, 07/29/2009 - 15:32
Thanks! Laurent.
I referred a link on "heirarchial QOS config" which you posted for someone's query in the same forum. Shall let you know if i have any/few queries.
Thanks!
adarsh Wed, 07/29/2009 - 15:43
Thanks! for your reply Laurent,
Here's the briefing on tests and few queries in the end, see if you can spare few minutes to clarify.
•The main physical interface is policed at 20Mbps with the class default in the parent policy map.
•Child policy is configured in the main physical interface.
•No policies are applied in the sub interfaces. Different VRFs corresponding to different customers are configured on each of the sub interfaces. Same IP addresses are assigned for all the sub interfaces for the testing.
•The child policy in the main interface has 4 classes defined and each class is policed to 5Mbps which different actions defined for in contract and out of contract traffic. The config is below:
R#sh policy-map interface gig0/3
GigabitEthernet0/3
Service-policy input: NNI-PIN-test
Class-map: class-default (match-any)
0 packets, 0 bytes
30 second offered rate 0 bps, drop rate 0 bps
Match: any
0 packets, 0 bytes
30 second rate 0 bps
police:
cir 20000000 bps, bc 625000 bytes
conformed 0 packets, 0 bytes; actions:
transmit
exceeded 0 packets, 0 bytes; actions:
drop
conformed 0 bps, exceed 0 bps
Service-policy : NNI-IN-test
Class-map: EXP5 (match-all)
0 packets, 0 bytes
Match: ip dscp ef (46)
police:
cir 5000000 bps, bc 156250 bytes
drop
Class-map: PREC4 (match-all)
0 packets, 0 bytes
Match: ip precedence 4
police:
set-mpls-exp-transmit 3
Class-map: PREC2 (match-all)
0 packets, 0 bytes
Match: ip precedence 2
police:
set-mpls-exp-transmit 2
set-mpls-exp-transmit 1
Class-map: PREC0 (match-all)
0 packets, 0 bytes
Match: ip precedence 0
police:
set-mpls-exp-transmit 0
drop
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
Have attached the config and shall be putting in next post as well to make things handy.
Queries:
•Will the total BW for all 'ef' marked packets from all the subinterfaces be policed to 5 Mbps or is it per subinterface?
•In either case, how do I see the BW consumption for each subinterface?
•How do I verify intercos bursting in this case?
adarsh Wed, 07/29/2009 - 15:45
Hi Laurent,
As mentioned in previous post here's the config (same as per the attachment uploaded earlier) from the interfaces in question:
R#sh run int gig0/3.2
Building configuration...
Current configuration : 153 bytes
interface GigabitEthernet0/3.2
ip vrf forwarding VRF1
ip address 10.1.1.1 255.255.255.252
end
R#sh run int gig0/3.3
interface GigabitEthernet0/3.3
ip vrf forwarding VRF2
end
R#sh run int gig0/3.4
interface GigabitEthernet0/3.4
ip vrf forwarding VRF3
end
R#
Laurent Aubert Wed, 07/29/2009 - 16:27
  • Cisco Employee,
A: Total Bw will be policed to 5 Mbps.
A: you can't as the classes are common to all VLANs.
A: Not sure to understand what you mean here..
Laurent.
