How to enable Windows Remote Desktop (3389) on Remote Access VPN
Jul 25th, 2009
We already have ssh to Linux boxes enabled via Remote Access VPN configured on ASA device (configuration below). How can we enable Windows Remote Desktop on Windows Machines.
Secondly, even though I can ssh into the servers via Remote Access VPN, if I do 'telnet x.x.x.x 22' after getting connected via VPN, it gets blocked. Why is it so ?
Thanks.
interface GigabitEthernet0/0
nameif outside
security-level 100
ip address 1.1.1.100 255.255.255.0
interface GigabitEthernet0/1
speed 1000
duplex full
nameif inside
security-level 100
ip address 10.0.0.100 255.255.255.0
passwd xxxxxxxx encrypted
ftp mode passive
dns server-group DefaultDNS
domain-name default.domain.invalid
access-list 22 extended permit ip any any
access-list 33 extended permit ip any any
access-list inside_nat0_outbound extended permit ip any 10.0.0.128 255.255.255.128
access-list cisco1_splitTunnelAcl standard permit any
mtu outside 1300
mtu inside 1500
ip local pool pool1 10.0.0.180-10.0.0.210 mask 255.255.255.0
ip verify reverse-path interface outside
ip verify reverse-path interface inside
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 0.0.0.0 0.0.0.0
access-group 22 in interface outside
access-group 33 in interface inside
route outside 0.0.0.0 0.0.0.0 1.1.1.120 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
sysopt connection tcpmss 1300
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 set pfs
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map outside_dyn_map 40 set pfs
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp nat-traversal 20
management-access outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
group-policy cisco internal
group-policy cisco attributes
vpn-simultaneous-logins 50
vpn-tunnel-protocol IPSec
split-tunnel-network-list value cisco1_splitTunnelAcl
group-policy cisco1 internal
group-policy cisco1 attributes
dns-server value 195.29.72.20
username cisco password xxxxxxxx encrypted privilege 0
username cisco attributes
vpn-group-policy cisco
username admin password xxxxxxxx encrypted privilege 15
tunnel-group cisco type ipsec-ra
tunnel-group cisco general-attributes
address-pool pool1
default-group-policy cisco
tunnel-group cisco ipsec-attributes
pre-shared-key *
tunnel-group cisco1 type ipsec-ra
tunnel-group cisco1 general-attributes
address-pool pool1
default-group-policy cisco1
tunnel-group cisco1 ipsec-attributes
pre-shared-key *
prompt hostname context
: end
fedecotof Sun, 07/26/2009 - 16:23
First of all, all IP traffic is going through the tunnel because you have a Split tunnel policy but it says to send
any traffic through the tunnel. (this means that when you connect with your VPN client, the machine will lose its local
access to the Internet and will send everything through the tunnel.
When you issue the command:
''show run sysopt''
There's going to be by default the ''sysopt connection permit-vpn'' command enabled. This means that all VPN traffic
is allowed to pass through without being checked by the OUTSIDE ACL.
In other words, as long as you're able to PING the Windows machines, you should be able to access them via Remote Desktop.
Remote Desktop uses TCP port 3339, just make sure the Windows Machine have the feature enable. (For example try to
Remote Desktop to that machine from the LOCAL network.
There's nothing on the ASA's config blocking IPsec traffic, so all IP traffic should go thorugh.
Let me know if you have any problems.
Federico.
tech_trac Mon, 07/27/2009 - 00:05
Thanks Federico.
I shall get back to you in a week's time.
Regards.
tech_trac Wed, 08/26/2009 - 23:27
When I log in via Remote Access VPN (with VPN Client), my PC is assigned an IP with a default gateway pointing to CAT65K.
Now when I try to ping the gateway, it fails. CAT65K log does not show any denied packets from my PC. But it shows a log on the ASA which is configured for Remote Access VPN with normal Built and Teardown messages.
What could be the problem.
Thanks.
fedecotofaja Thu, 08/27/2009 - 06:47
You need to determine what exactly do you want to accomplish with the VPN connection. I mean, do you want to send all IP traffic from the clients through the tunnel or would you like a split-tunnel policy to specify which traffic is going encrypted through the tunnel?
If you're sending all IP traffic, then when the VPN client connects, is going to get a default gateway from the ASA... because all traffic should be sent through the tunnel, but you're also having your normal default gateway on your local network connection.
In order to help you, let's determine if you need or not a split-tunneling policy and from there we handle the routing accordingly. What do you think?
Cheers.
Federico.
fedecotofaja Thu, 08/27/2009 - 07:47
Yes, I see you have defined a split tunneling policy. But that policy says to send all traffic through the tunnel (so is the same as not having a split tunneling policy).
The question is: Do you want to send all IP traffic from the clients through the tunnel or just to specific networks?
tech_trac Thu, 08/27/2009 - 08:03
I have defined specific networks as below
access-list splitTunnelAcl standard permit 192.168.169.0 255.255.255.0
access-list splitTunnelAcl standard permit 192.168.170.0 255.255.255.0
split-tunnel-policy tunnelspecified
split-tunnel-network-list value splitTunnelAcl
And this policy is attached to the tunnel-group cisco
