AP 1200 are not registering with WLC
Roman Rodichev Sat, 07/25/2009 - 19:48
AP's config is irrelevant, because it will be erased when LWAPP image is installed (only static management IP address can be saved).
The switch ports that AP connects to will have to be configured in 'switchport mode access'. You can put it in any VLAN you want as long as it has reachability to the WLC's management/ap-manager interface IP addresses.
WLC's interface on the switch should be configured as "switchport mode trunk"
Roman
Ok, now I recall this past week attempting to do the LWAPP upgrade on the access points, and I kept getting an error similar to the documentation where it shows something was stoping the upgrade tool to access the APs.
The computer used was windows xp and it was connected directly with the same subnet configuration of the APs. So, connectivity was not an issue. It was like if something in the access point was stoping the Upgrade tool from making any changes.
I had followed the instructions creating a text file with the following information.
ap-ip-address,telnet-username,telnet-user-password,enable-password
10.2.1.2 (AP ip address),admin,password,password
How do I troubleshoot this?
The instructions on the paper says..
Upgrade Tool Window-Firewall or Access Control List with Internal TFTP Server
Roman Rodichev Sat, 07/25/2009 - 20:26
was it complaining about recovery image not being right? (use older recovery image)
was it complaining about tftp not being able to start? (make sure tftp is not already running on your machine)
did you enable telnet access on WLC? (by defaul it's SSH only)
can you telnet to AP from your machine with that admin, password, password?
telnet to AP, enable "term mon", and try upgrade tool, watch for any error messages in the logs on the AP
upgrade tool basically telnets to your AP in the background, does a bunch of commands, downloads the image, and reboots. it also telnets to the WLC to check few things.
Roman
Roman Rodichev Sat, 07/25/2009 - 20:28
if you are interested, here's a script of what upgrade tool does on the AP. I captured it with wireshark
enable
Password:Cisco
AP1130#sh privilege
Current privilege level is 15
AP1130#show run | incl hostname
hostname AP1130
AP1130#test pb display
Display of the Parameter Block
Total Number of Records : 7
Number of Certs : 6
Number of Keys : 1
AP1130#term length 0
AP1130#show version | include Cisco IOS
Cisco IOS Software, C1130 Software (C1130-K9W7-M), Version 12.4(10b)JDA, RELEASE SOFTWARE (fc1)
AP1130#show controller | include Radio AIR
Radio AIR-AP1131G, Base Address 0022.904f.00b0, BBlock version 0.00, Software version 6.20.6
Radio AIR-AP1131A, Base Address 0022.903b.7ca0, BBlock version 0.00, Software version 6.20.6
AP1130#show controller d0 | include Current
Current Rates: basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
Current Voice Rates: basic-5.5 basic-11.0 6.0 12.0 24.0 [disabled until voice packet-discard enabled]
AP1130#show controller d1 | include Current
Current Rates: basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
Current Voice Rates: basic-6.0 basic-12.0 basic-24.0 [disabled until voice packet-discard enabled]
AP1130#show run | include station-role
station-role root
station-role root
AP1130#test pb disp
Number of Certs : 6
Number of Keys : 1
AP1130#show int F0 | include address
Hardware is PowerPCElvis Ethernet, address is 0021.d837.3340 (bia 0021.d837.3340)
AP1130#show int | include Dot11Radio
Dot11Radio0 is up, line protocol is up
Dot11Radio1 is up, line protocol is up
AP1130#show sntp | exclude SNTP
AP1130#config t
Enter configuration commands, one per line. End with CNTL/Z.
AP1130(config)#int Dot11Radio1
AP1130(config-if)#shut
AP1130(config-if)#exit
AP1130(config)#no boot manual
AP1130(config)#no boot enable-break
AP1130(config)#no sntp broadcast client
AP1130(config)#no timezone
AP1130(config)#int Dot11Radio0
AP1130(config-if)#end
AP1130#clock set 18:52:08 18 Apr 2009
AP1130#config t
AP1130(config)#line vty 0 15
AP1130(config-line)#exec-timeout 0
AP1130(config-line)#exit
AP1130(config)#exit
AP1130#show run
hostname AP1130
AP1130#arch down /over /create-space tftp://3.45.47.153/images/c1130-rcvk9w8-tar.123-11JX1.tar
extracting c1130-rcvk9w8-mx/info (273 bytes)
extracting info.ver (273 bytes)
[OK - 1873920 bytes]
Deleting current version: flash:/c1130-k9w7-mx.124-10b.JDA...
done.
New Software image installed in flash:/c1130-rcvk9w8-mx
Configuring system to use new image...
done.
archive download: takes 30 seconds
AP1130#show archive status
SUCCESS: Upgrade complete.
AP1130#write erase
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of nvram: complete
AP1130#dir flash:
Directory of flash:/
2 -rwx 0 Mar 1 2002 01:00:13 +00:00 validate.txt
3 -rwx 1048 Apr 18 2009 18:52:42 +00:00 private-multiple-fs
7 drwx 320 Jan 1 1970 00:06:08 +00:00 c1130-k9w7-mx.124-10b.JA3
6 -rwx 5 Apr 18 2009 18:53:01 +00:00 private-config
306 drwx 128 Apr 18 2009 18:52:35 +00:00 c1130-rcvk9w8-mx
157 drwx 256 Apr 19 2009 23:52:23 +00:00 c1130-k9w8-mx.124-10b.JDA1
15998976 bytes total (8625664 bytes free)
to be continued...
...continuing
AP1130#dir nvram:
Directory of nvram:/
30 -rw- 0 startup-config
31 ---- 0 private-config
1 -rw- 0 ifIndex-table
32768 bytes total (31692 bytes free)
AP1130#sh crypto ca trustpoints
AP1130#sh crypto ca certificates
AP1130#terminal length 0
AP1130#show run | begin BVI1
AP1130#more env_vars
BOOT=flash:/c1130-rcvk9w8-mx/c1130-rcvk9w8-mx
DEFAULT_ROUTER=3.45.47.158
ENABLE_BREAK=no
ENABLE_IOS_BREAK=yes
IOS_STATIC_DEFAULT_GATEWAY=3.45.47.158
IOS_STATIC_IP_ADDR=3.45.47.151
IOS_STATIC_NETMASK=255.255.255.224
IP_ADDR=3.45.47.151
MANUAL_BOOT=no
PWR_INJECTOR_DETECT=000d.2808.41e7
RELOAD_REASON=36
ROM_PERSISTENT_UTC=1014942940
TERMLINES=0
AP1130#more flash:/env_vars
ENABLE_BREAK=no
IP_ADDR=3.45.47.151
MANUAL_BOOT=no
RELOAD_REASON=36
TERMLINES=0
AP1130#reload
System configuration has been modified. Save? [yes/no]:yes
Building configuration...
Proceed with reload? [confirm]yes
Roman
Leo Laohoo Sun, 07/26/2009 - 02:28
Hoooooooo boy. This is going to be a looooooooong night. Please pass the grog.
I recommend that you spend time to get yourself acquainted with the Cisco Wireless LAN Controller Configuration Guide.
http://www.cisco.com/en/US/docs/wireless/controller/5.2/configuration/guide/Controller52CG.html
If you have been given the task of managing the WLN of your organization, this will give you a better understanding of what you will be dealing with and minimize the chances network outages.
Hope this helps.
Great News!
I finally got the Access Points working with my WLC.
The access points are showing on the WLC screen and obtaining their individual ip addresses.
Now, How do I ensure the wireless clients gets their ip address?
The wireless SSID is been advertised, but, the clients can not get an ip address.
I know when the AP were autonoumus, I could setup a VLAN for the clients. I do not know how to setup the same VLANs for the LWAPP access points.
