SRST from the start
Jul 26th, 2009
I went on a job interview and was asked what are the first two commands you put in the router for SRST. When the routers were set up for this I did it with a partner years ago (4 Years ago). Well i dident know the answer to the question and I have been searching for the answer. The person asking me said "once the commands are put in the do not show up on the config." I can not find these any place even though I have found alot on SRST.
Its good to get this down for my own general knowledge but I can seem to find this answer. Can some one tell me or point me in the best direction.
pcameron Mon, 07/27/2009 - 00:19
There are three commands you need for a minimal SRST configuration -
ip source address
The values for max-ephones and max-dn are platform dependent. Refer here for more details -
All these commands show up in the config.
You might be able to go back the prospective employer and argue the point :-)
