Jaime Valencia Sun, 07/26/2009 - 13:45
  • Cisco Employee,
  • Hall of Fame,
    2011
The configuration is the same you would use for any other router with MGCP.
There are plenty of MGCP config guides if you search CCO.
java
if this helps, please rate
