DFM 3.2.0 problems - fails to start
Answered Question
Jul 26th, 2009
DFM 3.2.0 is failing to start under Solaris.
I get the following under High Severity Alerts.
"An exception occurred.Please check the AAD.log file for further details."
The Critical Message Window under CS shows this:
"Processes DfmBroker are down"
AAD.log and pdshow attached.
Correct Answer by Joe Clarke about 7 years 11 months ago
Ye, tcp/9002 is in use by another process. You must free up this port, then restart dmgtd.
Overall Rating: 5 (1 ratings)
Joe Clarke Sun, 07/26/2009 - 16:48
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the /opt/CSCOpx/objects/smarts/local/logs/brstart.log. This is most likely due to a port conflict. DFM requires tcp/9002 to be available.
Correct Answer
Joe Clarke Sun, 07/26/2009 - 17:53
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
eidumsigfrid Sun, 07/26/2009 - 20:27
Ok managed to free up the port, restarted dmgtd, still no luck.
Decided to delete NMSROOT\log\pidm.log, restarted dmgtd and it worked.
