Telnet ans SSH on PIX515E not working
Answered Question
Jul 26th, 2009
I have two PIX515E (Primary and Fail-over) and i can't access them via telnet or SSH.
I can only access them once they are restarted and then they don't respond to me and close the connection.
the show version of the primary is as below :
Cisco PIX Security Appliance Software Version 8.0(3)
Device Manager Version 6.1(1)
Compiled on Tue 06-Nov-07 19:50 by builders
System image file is "flash:/pix803.bin"
Config file at boot was "startup-config"
Primary up 3 days 19 hours
failover cluster up 13 hours 18 mins
Hardware: PIX-515E, 128 MB RAM, CPU Pentium II 433 MHz
Flash E28F128J3 @ 0xfff00000, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : VAC+ (Crypto5823 revision 0x1)
0: Ext: Ethernet0 : address is 0019.e762.f577, irq 10
1: Ext: Ethernet1 : address is 0019.e762.f578, irq 11
Licensed features for this platform:
Maximum Physical Interfaces : 6
Maximum VLANs : 25
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : Unlimited
This platform has an Unrestricted (UR) license.
Serial Number: 810417710
Running Activation Key: 0x7785a916 0x349cafef 0x49afea88 0x8bbd3f92
Configuration last modified by enable_15 at 12:49:25.499 EEDT Sun Jul 26 2009
can anyone help me to solve this issue Please.
Correct Answer by Collin Clark about 7 years 6 months ago
I would upgrade to 8.2. I don't have the bug number but you should be able to find it in the Bug Toolkit.
Overall Rating: 5 (1 ratings)
Collin Clark Mon, 07/27/2009 - 11:43
It's a bug in 8.0(3). It drove me nuts for the longest time and finally Cisco gave me engineering code and it fixed the problem. 8.2 does not have this problem either.
Hope it helps.
ayman emara Mon, 07/27/2009 - 23:57
Do you mean that i shall downgrade to 8.0(2)?
can you give me the bug number
Correct Answer
Collin Clark Tue, 07/28/2009 - 05:10
