Strange empty NAT entry
Jul 27th, 2009
Hi All,
What's causing some work stations to create this strange NAT entry with no protocol defined and no Outside local and Outside global.
core2#sh ip nat trans | inc 172.16.75.139
Pro Inside global Inside local Outside local Outside global
--- 210.15.240.9 172.16.75.139 --- ---
tcp 210.15.240.9:5380 172.16.75.139:5380 61.137.191.125:80 61.137.191.125:80
Any ideas?
Thanks.
Andy
Roman Rodichev Wed, 08/05/2009 - 09:55
that a static NAT entry, look for "ip nat inside source static" in your config
regards,
Roman
asaykao73 Wed, 08/05/2009 - 16:53
Hi Roman,
Thanks for the reply.
There is no static nat configured which is why I'm puzzled by that entry.
core2#sh run | inc nat
nat server
nat server
nat server
nat server
nat server
ip nat outside
ip nat inside
ip nat inside
ip nat outside
ip nat inside
ip nat translation timeout 300
ip nat pool NAT-POOL 210.15.240.6 210.15.240.9 netmask 255.255.255.224
ip nat inside source route-map nonat pool NAT-POOL overload
route-map nonat permit 10
That's the whole config and you can see that there is no static nat configured anywhere.
I have a few dhcp clients doing this on the network.
Look for example at the dhcp clients of 172.16.75.23 and 172.16.75.239.
tcp 210.15.240.9:1024 172.16.75.239:49796 210.15.254.237:443 210.15.254.237:443
--- 210.15.240.8 172.16.75.23 --- ---
--- 210.15.240.9 172.16.75.239 --- ---
tcp 210.15.240.6:1024 172.16.75.26:49240 207.46.61.90:80 207.46.61.90:80
tcp 210.15.240.6:1025 172.16.75.243:50811 202.45.127.78:993 202.45.127.78:993
tcp 210.15.240.6:1032 172.16.75.232:51226 66.102.11.164:80 66.102.11.164:80
tcp 210.15.240.6:1026 172.16.75.232:51526 72.167.82.19:993 72.167.82.19:993
tcp 210.15.240.6:1027 172.16.75.241:49982 209.85.129.111:993 209.85.129.111:993
tcp 210.15.240.8:54775 172.16.75.23:54775 89.149.236.104:80 89.149.236.104:80
Thanks.
Andy
